    Jul 2004
    I have a problem with a file, im trying to author it to dvd but its not recognised by tmpge or dvdlab. Im not sure how it was created. Here is the info avi codec gives. It only plays with powerdvd, not vlc or wmp.
    File : 982 MB (0.0 B), duration: 0:00:00, type: MPG, 1 audio stream(s), quality: 90 %
    Video : 0.0 B, 15000 Kbps, 25.0 fps, 720*576 (2.21:1), MPG2 = MPEG 2 (SVCD/DVD), Supported
    Audio : 0.0 B, 256 Kbps, 48000 Hz, 2 channels, 0x51 = Mpeg-1 audio Layer 2 [0xc0], Supported
    Gspot says its am mpeg.
    Thankyou for any advice.
    15mbits/15000kbps is too high for dvd. reencode it with rejig or some encoder.
    and what is the error msg in tmpgenc dvd author or dvd-lab?
    Jul 2004
    ill get the exact details brb, i know its way high, i thought the file size would be larger.
    Jul 2004
    TMPGE just crashes now.
    Its very likely it was captured from tv.
    Fix headers comes up "nothing was done."
    Jul 2004
    illegal mpeg stream is what tmpgenc says
    Jul 2004
    MPEG-2 Validator v1.4.0.131 - 18/09/2005 23:45:01
    File under analysis: "C:\SONATA\green green grass\episode1.mpg"..!
    Begin Process:
    Begin Program Streams Summary:
    Missing Progam End Code...
    File "C:\SONATA\green green grass\episode1.mpg" is a MPEG-2 Program Stream
    MPEG file size 982.90 MB
    MPEG Packs = 503245
    Sectors delay = 46308321.4 ms
    *System headers = 0
    MPEG Pack Size = 2048
    Packets per Pack = 1
    Program Mux Rate = 9843 Kbps
    Total PES packets = 506797
    PES Packet Lenght Max. = 2028
    Number of Video Streams: 1
    Number of Audio Streams: 1
    Padding Stream, packets = 3552, Total = 3531 KB
    MPEG Audio stream, ID: C0
    PES packets = 27055,
    Total = 52.63 MB
    Video stream, ID: E0
    PES packets = 476190,
    Total = 916.11 MB
    End Program Streams Summary.
    Begin Video Streams Summary:
    End Video Streams Summary.
    Begin Audio Streams Summary:
    Elementary Stream C0 is a MPEG Audio Stream
    Audio Delay Stream C0 = 46308586.7 ms
    Audio decoded bytes = 327900672 -> 1707.82 Sec
    Found 0 sync words
    Audio Sync Losses: 0
    Layer = 2
    bitrate = 256 Kbps
    Frequency = 48000 Hz
    Error protection = Enabled
    Private flag = 0
    Mode = stereo
    Copyright flag = 0
    Original flag = 0
    Emphasis = none
    Left Channel DC Level = -100.0 dBFS
    Right Channel DC Level = -100.0 dBFS
    Left Channel Peak Level = -2.0 dBFS
    Right Channel Peak Level = -1.9 dBFS
    *Left Channel RMS Level = 42.6 dB
    *Right Channel RMS Level = -23.9 dB
    *Difference Left-Right RMS Level = 66.5 dB
    End Audio Streams Summary.
    Video Stream Duration: 0.00 sec -> 0:1242064 (secs:frames)
    Duration Difference from Video to Audio = -1707816 msec
    Initial Delay Audio to Video (PTS based) = 46308587 msec
    Processing time: 00:03:05
    Result:
    Compliance Test: Fail!!
    End.
    Elementary stream E0 is not a mpeg-2 video stream
