Hi,
I tried to convert AVI to MPEG2, using DVD2SVCD.
The audio was out of syncronize with the video: The audio speed was double than the video stream.
I know that the parameters are well, since this is not my first time using the DVD2SVCD.
Can you help me?
Uriel
Results 1 to 10 of 10
Sorry, but I tried to upload the GSPOT screenshot but couldn't succeeded:
I write down in the Image or File text field the following:
and click on Submit button, but nothing happend.
What is wrong?
Uriel -
You need to include the filename with .jpg extension. Also it must not have any spaces in the filename or it won't be recognized. You can also use a photo website like www.photobucket.com to store your pictures online.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Thanks: This is what I did. I clicked on browse, navigated to the file folder and click the file name and OK (It is in C:\Documents and Settings\Uriel\Desktop\avi.jpg)
Added [jpg] before the file name and [/jpg] after the file name.
At the end it was like:
[jpg]C:\Documents and Settings\Uriel\Desktop\avi.jpg[/jpg]
And Click on Submit.
Uriel -
Oh you need to use the
tags around the file name.
The out of sync of probably due to a bad resampling of your audio file from 32000 hz to 48000 hz.
Try demuxing the wave file and convert it to 48 khz with an audio processing tool.
Then in dvd2svcd, select your video file and the new wave file as audio source (I hope that svcd2dvd can do that) and try to reencode.
PS: here is your screenshot working in the forum:
AVI to MPG Conversion Audio Problem - please help!
By Nuzy in forum Video ConversionReplies: 4Last Post: 17th Nov 2010, 22:34 -
audio distortion with mpg to flv conversion
By grampazero in forum Newbie / General discussionsReplies: 3Last Post: 3rd Apr 2010, 02:06 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
choppy audio from mpg to DVD conversion - Help
By Warhammerx in forum Video ConversionReplies: 4Last Post: 7th Dec 2008, 18:25 -
mpg to avi conversion
By rwagar in forum Video ConversionReplies: 1Last Post: 27th Mar 2008, 22:27
