I have had Decrypter for abot 6 months and never had a problem until now. I had 3 DVD-R of home movies that I wanted to rip and combine into 1 disk cause each disk is only 30 minutes long. When taking them to the HD with Decrypter everything appeared to work fine. I then attempted to open the DVD files with TMPGEnc DVD Author ( As I have done hundreds of times with no issue ). When it brings up the title selection screen is says there are 2/3 titles to choose from but no titles show in the window for me to select. The DVD's and the DVD files play fine in Windows Media Player. I don't know what the problem is. I tried re-ripping to no avail. The 3rd disk out of the 3 works fine and brings up one title for me to select in Author. Any ideas of what the problem could be with teh other two???
Looks like I stumped the experts too. This is a really weird problem I have here. There is no reason it should not be working.
Try an alternative software, give DVD Shrink a go. Use reauthor mode and see if it allows you to select the three titles from each disk.
Forgot to add, if your keen on using TMPGEnc DVD Author (ive never used it), you could however delete all the IFOs and BUPs of the dvd (not the VOBs). Create new ones using IFOEdit, and then try TMPGEnc.
TMPGEnc Dvd author 3 problem
By prcole18 in forum Authoring (DVD)Replies: 7Last Post: 7th Oct 2008, 12:33 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
menu problem in TMPGEnc DVD Author 3
By sanduul in forum Authoring (DVD)Replies: 13Last Post: 23rd Oct 2007, 20:20 -
TMPGEnc DVD Author 3 - Playback problem, Help!
By cbales_24 in forum Authoring (DVD)Replies: 2Last Post: 18th Oct 2007, 17:29 -
TMPGEnc DVD Author 3 (MENU PROBLEM)
By jaffacaique in forum Authoring (DVD)Replies: 9Last Post: 18th Sep 2007, 20:43
