People,
I have a flac file and want to convert to .wav.
I have Monkey's audio but could not see how it be done.
I tried 'ufony', conversion was made to a .wav but it seemed I was hearing a 76rpm record at 16 rpm speed ,basically a droooone[ rhetoric comparision]
any help please ?
Monkey's Audio does .ape files. For .flac files you need FLAC. I recommend FLAC frontend as a convenient gui.
-drjThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
you definately need flac installed on the system, but my recommendation is dbpoweramp with the flac plugin for it........provided you set everything up properly, dbpoweramp can be used to convert just about ANY audio file into another form (except the yucky DRM'ed WMA files..........)
Convert flac or wav to lpcm
By wiseant in forum AudioReplies: 7Last Post: 30th May 2012, 19:02 -
FLAC to DTS Help
By The_WRATH in forum AudioReplies: 3Last Post: 22nd Nov 2011, 19:00 -
How to convert .BUP and .IFO to AIFF, AU, FLAC, M4A, OGG Vorbis or WAV
By MLK3329 in forum Video ConversionReplies: 6Last Post: 5th Oct 2010, 21:13 -
DVD to FLAC/SHN/WAV?
By Salva Veritate in forum DVD RippingReplies: 1Last Post: 26th Sep 2007, 23:56 -
FLAC, should i use this?
By SE14man in forum Newbie / General discussionsReplies: 23Last Post: 7th Aug 2007, 10:17
