How can i add a subtitle (DVD or permanent) to a mpeg movie and than burn into DVD?
use a dvd authoring with subtitle support like dvdauthorgui,dvd-lab pro, ulead dvd workshop.
I did do it. But there were some problems. The dvdauthorgui i manage without problem (it looks very simple) but becouse i am use to work with TMPGEnc DVD author i didnīt know how to put a menu on the dvdauthorgui. And since i pretend to make a DVD using multiple video files i didnīt know what to do.
The other problem was in the dvd lab, there i couldīt even find how to put a subtitle
can u help me? -
I would suggest gui for dvdauthor. There is very good tutorial at the download page.
Convert from MKV to AVI (mpeg-4 codec) + add subtitle to the video file
By kovacic_10 in forum SubtitleReplies: 3Last Post: 19th Feb 2011, 17:38 -
Is there anyone who use FFMPEG to add subtitle?
By Chris K in forum Authoring (DVD)Replies: 4Last Post: 15th Dec 2009, 12:07 -
create/add subtitle
By akakiami in forum DVD RippingReplies: 1Last Post: 15th Aug 2008, 04:40 -
How can I add a subtitle into ts file in DVB subtitle format
By elmc in forum SubtitleReplies: 1Last Post: 20th Jul 2008, 14:37 -
How to add subtitle to a video
By Chuba753 in forum SubtitleReplies: 7Last Post: 7th Jun 2008, 21:31
