Results 1 to 15 of 15
    Nov 2003
    Sherman Oaks. CA
    I have a 230mb mpeg2 that I can make into a 50mb HTPC quality file @ 50mb or even handheld quality @ 12 or so mb, but I'd like to make it 3mb (for emailing) and still look good. 1. Is there a coec I can use to d that and 2. if so, what tool do I need for the convrsion? Aren't real files very small?
    how many minutes is the clip? the source file size does not matter.
    what resolution/screen size would be okey?
    Nov 2003
    Sherman Oaks. CA
    Really any screen size is ok - it's just to check it out before getting the DVD tomorrow. It's a 6min. clip.
  4. Member yoda313's Avatar
    Jun 2004
    The Animus
    WMV will work. Try windows movie maker (xp only). Does great and has multiple resolution options and you can specifiy your file size.
    Nov 2003
    Sherman Oaks. CA
    Hmm - didn't know it converted mpeg2s (have used it for DV AVI). I'll give it a whirl- can someone on a Mac watch it?
    When previewing in movie maker, I don't see a picture - just sound....
    Nov 2003
    Sherman Oaks. CA
    One last thing - is there a great all in one conversion tool out there where you can pick any format to any format?
    Mar 2003
    Kansas City MO
    Does life come in one neat little package? No!
    Nov 2003
    Sherman Oaks. CA
    There must be something that does a lot.
    Any insite as to why I can't see the mpeg2 or why it says it would ake 1400mins. to convert to an emailable file?
    Nov 2003
    Sherman Oaks. CA
    I went in a cleared all the filters in Moviemaker, and now I can see the video - hmm. Wonder which it is...
  10. Video Restorer lordsmurf's Avatar
    No. Everything has limitations.
    In fact, most software that does too many things gives poor quality output.
    You simply cannot cram that much code into on program and expect flawless high quality results. Just look at Windows.
    Nov 2003
    Sherman Oaks. CA
    Unless I'm doing something wrong, a 5mb wmv file from a 235mb mpeg2 looks pretty awefull.
  12. Member Soopafresh's Avatar
    Jan 2004
    It's 1/40th the size.... Make your target file 240x180.
    Nov 2003
    Sherman Oaks. CA
    Ok - will give that a go. Didn't see resolution choice but wll look.
    Also, the reason I couldn't see the mpeg2 was 'cause of the snapstream audio decoder filter - make any sense?
    Can't find resolution settings....Just size and for various devices...
    Tried all the settings and not give that particular resolution.
  14. Member yoda313's Avatar
    Jun 2004
    The Animus
    Choose video for pocket pc and it will use a resolution of 208 x 160 (pretty close to that target)
    Another option would be to select a higher file size output and then split it. You could make a couple of zip files if you need to email them and you have a limit.
    Nov 2003
    Sherman Oaks. CA
    Thanks!!
