Hi,
I want to buy Canopus ADVC-55 converter but I have a question:
- My computer is a laptop and I have a PCMCIA FireWire card ( Conceptronic SnapPort FireWire PC Card ), here you can see details:
http://www.conceptronic.net/site/DesktopDefault.aspx?tabindex=1&tabid=200&Cat=30&grp=3...&Prod=CSP1394C
- I want to know if I also need to buy Canopus power supply for ADVC-55 device or simply it will work with firewire power supply.
Thank you in advance.
I go from six pin to six pin, and I don't have an external power supply. I assume you wouldn't either, and judging by that PCMCIA card, it's a 6 pin. You should be in the clear.
It's not clear if that PCMCIA card can supply power, especially enough for the Canopus unit. The ADVC-55 seems to draw about 600MA. I would get a power supply.
The laptop PCMCIA Firewire card I have has a plug in for an external power supply, but I use the supply that came with my ADVC-100 when I use it on the laptop.
I think it's probably better not to draw power off the laptop if you don't really need to. -
Or look into an external (self powered) unit such as the Plextor, or the ADS Pyro AV/Link. They work very well.
Rob
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum Capturing and VCRReplies: 33Last Post: 6th Oct 2012, 18:26 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 20:52 -
Capturing with Canopus ADVC
By BonnieW88 in forum Capturing and VCRReplies: 3Last Post: 29th Nov 2009, 21:55 -
Canopus ADVC-55 vs. ADVC-110
By bcags7 in forum Capturing and VCRReplies: 4Last Post: 2nd Nov 2008, 15:15 -
Canopus ADVC 110 video out question
By Darkestred in forum Capturing and VCRReplies: 5Last Post: 3rd Aug 2007, 22:12
