Hi there, I have some question for my multiple dvd burner setup
at this moment I have 3 pioner 108, and 1 pioneer 110d
my setup:
2 pioneer 108 (master and slave) on IDE1
1 Pioneer 108 and 110d (master and slave) on another IDE, I bought a PCI card for adding this 2 drive since IDE0 is used for HDD. My windows read this drive as SCSI
I tried to burn 8X with Nero and using multiple burner option, but they don't like the SCSI, the seems slowing down all.
usually i can burn with 8X speed about 8 minutes, but once I combined with the scsi the will take about 30 minutes
my question, is there anyway to fix this and make the 2 'SCSI' burner work with the other 2 without slowing them down
I'm considering to buy either DVDduplicator barebone or just try to daisy chain them with firewire
any good brand for duplicator controller? and is this ok if I combined the burner (108 and 110d), or they should be identical?
just need expert recommendation about this, any link will be great
You created a bottle neck by mixing ide with scsi .
If the motherboard was pure scsi for all devices , and all drives were scsi interfaced , there'd be no problem .
The best method is either all ide or all scsi , not mixed .
Mixing is normally associated with raid setups anyway , for backup or video capture .
As it appears you are mass producing , a duplicator is far better in the long run , and there are now a few available at good prices .
What you are doing at the moment is streching the pc out , and placing it under quite considerable stress , and I am surprised the hard drive has started producing bad sector's . -
Hmm.. I just bought the ACARD barebone
now my question is am I ok with 3 Pioneer 108 and 2 Pioneer 110D
should I not mix them up again?
burning multiple mp4 files to DVD format
By dvdnewbie64 in forum Newbie / General discussionsReplies: 2Last Post: 20th Mar 2009, 13:59 -
Burning 1000's of files to multiple dvd's
By lordhutt in forum ComputerReplies: 12Last Post: 14th Dec 2008, 15:45 -
Burning multiple .MDF files to DVD
By henry13 in forum MacReplies: 10Last Post: 26th Jan 2008, 13:01 -
Burning Multiple AVI's with Menu
By Candoo in forum Authoring (DVD)Replies: 12Last Post: 8th Jan 2008, 17:52 -
Help burning multiple 8cm DVD+RW from Camcorder to 12cmDVD+RW
By WOWSY in forum Newbie / General discussionsReplies: 0Last Post: 3rd Jul 2007, 13:48
