I have the AC3 component for Quicktime. I've encoded some .avi files (both divx and Xvid) using Handbrake and ffmpegX with 5.1 AC3 audio. For some reason when I play the files in quicktime, the audio isn't there.
I think I used to have this working in the past, but I'm not positive.
Can anyone help?
Thanks.
-- sdm --
Well it appears that QT 7.02 broke the AC3 playback.
I'm surprised noone here had the same issue.
You can download the QT 7.01 re-intaller here:
http://www.apple.com/support/downloads/quicktime701reinstallerforquicktime702.html
This fixed the problem for me.
--sdmvisit my photo retouching website: http://www.shiftstudio.ca -
most of us AREN'T using Quicktime 7.01/7.02,
because they suck @$$. Many of us are still
using QT 6.52, unless you adopted using Toast 7
[macuser comes READILY to mind
], then you
had to move to QT 7.
QT 7 is getting to be Apple's big egg on the face lately...."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
I'm not so sure MOST aren't using QT 7. I installed it along with tiger as soon as they came out. This is really the only issue I've had. Maybe I'll set up a poll.
I also bought macuser25's highly touted video tool for all video. - Toast 7 -
=}visit my photo retouching website: http://www.shiftstudio.ca -
Thanks NarenFish.
I'd acutally prefer to keep the ac3 audio because (I believe) mp3 doesnt support 5.1 channels.
Actually is that true?
-- sdmvisit my photo retouching website: http://www.shiftstudio.ca -
There is a 5.1channel mp3 encoder/decoder available (that is based on the MPEG 2.5BC spec, as opposed to the usual 2 channel MPEG1/MPEG2 spec). It's from either Philips or Fraunhoffer (SP?). It is still quite experimental, even though the format has been officially ratified.
For all normal purposes though, mp3 should be considered 2channel. And in that case, AC3 would make more sense for 5.1--especially since you wouldn't need to reencode.
Hope that AC3 component gets updated soon, or QT7 fixed, or both.
mkv with ac3 audio -> avi with ac3 audio ? is this possible?
By Substance001 in forum Video ConversionReplies: 9Last Post: 21st Jun 2011, 00:56 -
video and audio stutters in quicktime
By lskwarek in forum Newbie / General discussionsReplies: 3Last Post: 9th Jun 2010, 13:26 -
quicktime conversion and maintain 5.1 AC3 sound
By theendisnye in forum Video ConversionReplies: 2Last Post: 12th Dec 2008, 02:36 -
FAVC re-encodes AC3 audio even when I check the "retain AC3" opti
By teapot in forum Newbie / General discussionsReplies: 2Last Post: 9th Nov 2008, 01:10 -
Quicktime 5.1 to 5.1 ac3?
By piratehunter in forum AudioReplies: 18Last Post: 7th Jun 2008, 21:54
