Just burned my first DVD ever and stuck it in my Pioneer. It loads, says "DVD" but when the movie starts I get good sound but the pic is scrolling erratically and is black and white. Reminds me of a VCR with the tracking not set properly.
This DVD was converted from a DivX avi via avi2dvd then burned with CloneDVD2 2.8.3.3 via an NEC 3540 onto a Memorex DVD+R 8X.
Coincidentally, I used the same DVD+R to record a VCR onto DVD with a Sony DVD/VCR recorder I bought then returned and one copy did this scrolling thing and the next one didn't.
I figure the player just doesn't like these Memorex DVD+R's but I'm not sure.
Wondering if I should try a different converter/burner or if I'm just screwed out of this stack of DVD+R's? Thoughts?
Also, if anyone has suggestions on the best media that can be bought locally at stores like Wal-Mart, Target, CC or BB I'd appreciate it... if you think that's the problem.
Ok I see that 25fps is PAL. So I'll try and convert. Sheesh I guess another 9 hours...
thanks. -
or try change the PAL/NTSC settings on your dvd player or TV.
i have noticed most list this player as PAL compatible, but mine isn't playing this. wondering now if it could be the +R. i dunno. guess we'll know once this PAL avi gets converted to NTSC.
(avstodvd) Converting m2ts to dvd...sudden sync probs.
By newbtube in forum Video ConversionReplies: 17Last Post: 2nd Apr 2011, 23:27 -
DVD FLICK audio sync probs
By dalek7 in forum Authoring (DVD)Replies: 2Last Post: 19th Aug 2010, 02:14 -
DVD Shrink Probs..
By Superstar24 in forum Newbie / General discussionsReplies: 33Last Post: 19th May 2008, 15:54 -
More dvd printing probs with r200
By parman in forum MediaReplies: 4Last Post: 28th Dec 2007, 16:14 -
tiem dealy probs with dvd player & pvr
By TILTNTURN in forum Newbie / General discussionsReplies: 1Last Post: 17th Aug 2007, 10:21
