Good (evening) all
I have been attempting to capture AVI files usind the Leadtek TV2000 Expert card with a max resolution of 352x576.
I have used different programs including the PVR, DScaler and VirtualDub. The captured video is "blurry", especially when there is motion involved. I recently re-formatted my drive and started from scratch to no avail.
Any suggestions![]()
Doug - Australia
I too have the same card and I am limited to 720 x 288? it is the best i can get please let me know if you find a resolution?
Thanks -
Have solved the problem...
I was running 2xSATA drives. I removed the smaller one and put my old 80Gb IDE back in. I then ghosted WinXP onto the smaller drive, reformatted the 200Gb SATA drive and used it only for capturing.
All now works fine... obviously doesn't like 2 SATA drives...
Doug
TV2000 XP Expert No Sound
By cbr549 in forum Capturing and VCRReplies: 5Last Post: 5th Dec 2010, 13:29 -
Trying to use VirtualVcr with Leadtek Tv2000 expert.
By GLE3 in forum Capturing and VCRReplies: 0Last Post: 20th May 2009, 10:46 -
Help: No sound at all with a Winfast TV2000 XP Deluxe
By Deathwish238 in forum Newbie / General discussionsReplies: 3Last Post: 18th Aug 2007, 13:01 -
Problem with WINFAST TV2000 XP Expert tv capture card.
By trueman in forum Capturing and VCRReplies: 1Last Post: 5th Aug 2007, 12:00 -
Leadtek Winfast TV2000 xp deluxe help
By Nuwanda in forum Capturing and VCRReplies: 0Last Post: 6th Jun 2007, 14:22
