  1. Hello everyone,i'm a newbie to this site and that i did try to search for my problem i've been having but cannot find the answer..so please don't flame me if this question has been answer already.My problem is i download chinese long chapter movies 1-40 chapter it's .rmvb file so i use Winavi to convert to .vob and use dvdshrink to re-author the movies and combine them to .iso file "note when i use dvdshrink i did not use any compression because i want quality"and use neroexpress to burn it to dvd so i can watch it on my home dvd player the problem is when i burn the first 1-3 chpter it can't play on my dvd paler it stated "playing this disc prohibited by area limit" but the rest on the movies 4 and up play just fine on my dvd player i don't knoe what's wrong maybe they use protection software on the first 3 chapter?I even check and make sure it's "region free" in dvdshrink b4 i burn to .iso file can anyone help me with is situation i have BENQ 1620 pro with hack firmware and my disc is Taiyo Yuden 16X
    Thank You
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Sounds to me it is in fact not a region limitation as such since DVDShrink by default will output region-free. More than likely your DVD Player can only play NTSC, and chapters 1-3 are PAL.
    If in doubt, Google it.
  3. jimmalenko,thank you for your advice hmm i'never thought of that when i think about it,when i download the movie the first 3 chapter has a different name from the rest is there any conversion software out there that can convert pal to ntsc?
  4. jimmalenko,you're right i just use winavi to convert to ntsc i did'nt know winavi has that option... thank you so much..awe...i waist like 8 good dvd disc... i should have ask videohelp first..anyway thank you again and again now my frustration is over
