i have attached a link to a file that i have just exported in fc5. i remember seeing these sort of line when you try to convert ntsc to pal through procoder, and the quality is not good. when i view this clip in fc5 it looks great, none of the lines you see in the link appear, but when you export it they seemt to show up, and really show up on the tv when you export it to dvd and play it.
my settings for exporting are
export quicktime compressor
choose dv pal as the type of output, as it is going to dvd
then just press go
the link for the file is
www.stuntastics.com/fc5help.htm
it is a 14meg file, it will just display the quicktime symbol, then white screen, when you see a picture, hit the space bar and it will play. but it is a small clip, raw data, if anyone can see the lines i am talking about and maybe explain why they are coming through in export that would be awesome.
bret
MainConcept H.264 frame rate issues encoding Final Cut output
By soandso in forum Video ConversionReplies: 2Last Post: 26th Jan 2010, 12:46 -
Importing DVD Files for Use in Final Cut?
By The Monkees in forum MacReplies: 8Last Post: 29th Dec 2007, 09:20 -
final cut pro - training on a DVD?
By Bansaw in forum Newbie / General discussionsReplies: 0Last Post: 29th Oct 2007, 04:04 -
importing commercial DVD's to final cut
By aquafinity in forum Newbie / General discussionsReplies: 0Last Post: 24th Jul 2007, 16:31 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 10:05
