I just downloaded and installed Subtitle Workshop along with the codec linked to the same webpage. I get no audio when I play an avi clip. I have search Subtitle workshop's webpage but found no answers. I registered with their forum so that I could post this question but have still not received permission to post. Can someone give me some suggestions on where to start?
	and you get audio when you play with windows media player?
 what is the audio codec? use gspot to identify.
	hi!
 I had the exact same problem a few days ago. Turns out, I hadn't configured ac3 correctly, but had never noticed because I play my files on vlc. When I started to actually do some work, the misconfigured codec gave me that problem. SW was working well, but I couldn't hear the audio because ac3 had the volume too low and/or wasn't specifically configured as the default decompressor. Once I reconfigured and restarted SW, it worked a wonder.
 I read about others with this problem, and often they've had SW trying to play the audio with ffdshow or some other compatible method. They solved by either configuring ffdshow to not play ac3, or uninstalling ffdshow altogether.
 That being said, it was working a wonder for a few days until right this moment (found this post while searching for a solution). suddenly, out of the blue, I'm out of sound again   ...while working on the same file! ...while working on the same file!
 are there any other ideas out there?
 [EDIT] Sorry! my bad! It wasn't the same file... I misnamed my files, and I was trying to have SW play sound on a soundless avi.... It wasn't the same file... I misnamed my files, and I was trying to have SW play sound on a soundless avi....
  Convert pac subtitle to something that I can open in Subtitle workshopBy Tiger_1982 in forum SubtitleReplies: 11Last Post: 15th Aug 2015, 21:49
  Subtitle Workshop - not creating subtitle at current time locationBy botjocrow in forum SubtitleReplies: 0Last Post: 14th May 2011, 04:09
  No audio in Subtitle Workshop 2.51By ukb007 in forum SubtitleReplies: 0Last Post: 13th May 2010, 17:40
  Subtitle Workshop - audio sync issues/crashingBy ecc in forum SubtitleReplies: 3Last Post: 30th Mar 2009, 23:59
  Subtitle Workshop 4 crashes when loading subtitle fileBy Batou in forum SubtitleReplies: 0Last Post: 26th Mar 2009, 07:57
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
