  1. I am creeting a video in MPEG video wizard and everything is working fine, except I keep getting these little scratching sounds periodically thoughout the songs (MP3 files) I am using. Any idea why this is happening or how I can fix it?
  2. Member kryten3000's Avatar
    Sep 2005
    New York, USA
    If you would please provide more specifics:
    -What is the source of your MP3's?
    -Why are you using MP3?
    -Are you making VCD, SVCD, DVD or some non-compliant format
    I don't want to trivialise your problem, but I do think a higher quality source would be in order i.e. PCM extracted from CDDA or AC3?
    If you are creating the MP3 yourself what ripping program are you using? Also what MP3 compression codec are you using?
    Any other detail would be helpful as well
  3. Kinda of new at this so please bear with me. I am using MP3 files that I downloaded. I am making a dvd, but before it even gets to that point I am hearing the strange sounds while I play it through in Video Wizard.
    Thanks for responding
    Its only the sound that is getting slightly distorted, my DVD sound is fine.
  4. Can anybody help me with this? Please!
