  1. I was reading system requirements for Photoshop CS2 and it only lists Pentium CPUs. Is there some reason this won't run on AMD CPUs or are they just being morons? I'm got a Venice 3000 in one machine I was thinking of putting PS on.
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Um thats not possible is it? I mean AMD isn't a pure intel clone anymore like the old 386 and 486 were. BUT if they have windows xp I think it has to run it.
    USA
    They are probably just saying Pentium speed/power or equivalent and not saying it too well. It will probably even run on a 400 Celeron if you don't mind slow with some operations.
    EDIT: It may be 'Optimized' for Intel processors, but a fast AMD should work fine.
  4. I figured that's what they meant but when they fail to be specific I have to worry about it. I guess I could put the trial on to be certain.
  5. Member yoda313's Avatar
    Jun 2004
    The Animus
    There you go good idea Besides as long as it says XP you shouldn't have any problem.
  6. Just installed it and it seems to work fine. Hell, it's faster than my P4 rig so far.
