is it possible to put more than 1 divx/xvid file onto 1 single dvdr and play it in dvd player that supports divx format.
Should be. As long as the physical file size isn't larger than the blank dvd it should just play it consecutively. As far as I know you still can't make true menus for divx files. It should just play back to back is my opinion
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
there is no menu support for divx yet, no....however a good chunk of dvd players that support divx have the option to pull up a filelist upon insertion of a data (non dvd) disc or audio cd to pull up a track list....its kind of a generic menu if you will though.....also, as long as the file doesnt have chaptering (which most dont) you can just use the chapter skip (at least on my player) to jump to the next divx file...hope that helps ya some.
Originally Posted by boldyIf in doubt, Google it.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
DVD to avi/DivX
By nempo in forum DVD RippingReplies: 4Last Post: 6th Apr 2010, 21:47 -
DVD to AVI (done) to Divx or xvid
By Grumpy_one in forum DVD RippingReplies: 3Last Post: 16th Mar 2009, 17:28 -
Best DVD to DivX / Xvid avi
By spidey in forum DVD RippingReplies: 6Last Post: 3rd Jul 2008, 14:20 -
Which is best app for DVD to DivX or AVI....?
By snadge in forum Newbie / General discussionsReplies: 26Last Post: 1st Feb 2008, 11:14
