I captured a movie from a VHS tape last weekend through a VCR (obviously) using a Happague WinTV 2000 Card. I captured to VCD fine dropping only about 30 frames in 2 hours, but here is my problem:
1) The entire movie captured at a bitrate between 150 and 300 kbps the entire movie. It looks horrible. How do I increase the bitrate so it looks halfway decent and what would bitrate would you recommend for a VHS to VCD capture?
2) What is the native resolution of a VHS tape? I was thinkng about capturing to SVCD but I don't want it to end up looking distorted and pixelated.
BTW I used VirtualDub and NTSC for all of this...
VCDs HAVE to have a bitrate of 1150 kps. If you don't record at that bitrate, it's an xVCD and not a true VCD, which might not be as compatable with your player. For more info http://www.vcdhelp.com/vcd.htm
The guides on this site will be a great help to get you going. Read them first and if anything confuses you, ask in the forums.
Most people agree that the best quality captures are acheived through capturing with MJPEG or HUFFYUV codecs. Read about this technique here:
http://www.vcdhelp.com/mjpeg.htm
Other capturing techniques are also covered in detail here:
http://www.vcdhelp.com/capture.htm
150->300kbps is far too low to produce even watchable videos.
Hope this helps -
I followed the MJPEG guide exactly. Even with the quality at 20 it still maxes at like 400 kbps.
Question about capturing Doctor Who VHS tapes
By fatcharlie in forum Capturing and VCRReplies: 30Last Post: 4th Apr 2011, 00:42 -
Question/Opinion: Capturing from VHS to digital, then to DVD
By SupaDupaMonkey in forum Capturing and VCRReplies: 12Last Post: 11th Jun 2009, 17:28 -
Capturing DV VHS deinterlace question
By bgmagic in forum Video ConversionReplies: 3Last Post: 13th Nov 2008, 09:57 -
Question about capturing VHS tape to .avi file
By rfdillon in forum Capturing and VCRReplies: 6Last Post: 27th Jul 2008, 01:44 -
Question about color space using a DV camcorder for capturing VHS
By binister in forum Newbie / General discussionsReplies: 16Last Post: 12th Jan 2008, 19:14
