I have a bunch of video clips which i have converted to mpeg2 using WinAVI converter. the resulting files play back fine, with no audio sync problems.
however i then use tmpg dvd author to prepare them all to go onto a single disc (with menu etc) and after doing so, the audio loses sync with the video - i need not burn the disc, just playing the vob files back on the computer does this
it sounds like a sample rate problem - the audio begins in sync, then gradually loses sync as the file is played, becoming more and more in front of the picture.
the clip format (before authoring) is this
MPEG2 720x480 29.97fps (4:3) NTSC 9000kbps
DD AC3, 48khz stereo, 224kbps
any ideas? as i mentioned earlier, the audio is perfectly in sync *after* converting the clips from AVI to MPEG2, the sync only dies when i actually author the things...
Results 1 to 1 of 1
TMPG DVD Author-old version
By Mållgan in forum Authoring (DVD)Replies: 12Last Post: 7th Mar 2010, 17:46 -
TMPGEnc DVD Author 3 gradually loses audio sync
By timmus in forum Authoring (DVD)Replies: 1Last Post: 6th May 2009, 18:24 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 04:56 -
About the .srt subtle files and the TMPG DVD Author
By ihmcjacky in forum Authoring (DVD)Replies: 2Last Post: 10th Mar 2008, 11:58 -
tmpg dvd author 1.6 help plz
By nwa in forum Authoring (DVD)Replies: 8Last Post: 6th Jul 2007, 19:59
