I downloaded the new SVCD2DVD and now I noticed that I don't have the bottom window where you can see the progress of the program listed. I know this is something simple but right now there's no window when I use the program. Where can I turn that on?
Can you try deleting any dnb_xxxx.xml files in the SVCD2DVD folder to see if that resolves the issue?
Window 7 Usable RAM question
By SE14man in forum Newbie / General discussionsReplies: 8Last Post: 10th Apr 2011, 07:19 -
Firefox question - extension for scrolling URL window?
By Hank Kinsley in forum Off topicReplies: 1Last Post: 2nd Oct 2009, 07:34 -
Quick question about progress.app
By aeslis in forum ffmpegX general discussionReplies: 1Last Post: 18th Jul 2009, 10:21 -
AviAddXSubs simple question (hopefully!)
By vladman2nd in forum SubtitleReplies: 1Last Post: 8th Jul 2008, 01:01 -
Simple Mplayer Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2008, 21:10
