i just started using ulead movie factory 4 and i authored some videos that are .mpg. i put an image as background for the menu and i also put a mp3 for background sound. then i burned it to a dvd,. the problem is that after i burned it i cannot play it in my dvd player. why does this happen? can somebody help? a step by step guide would be very much appreciated. thanks so much,.![]()
mp3 is not part of the DVD spec. If you use mp3 for audio, it violates the DVD spec and chances are your DVD player won't recognize it.
To be playable on most players, a DVD must adhere to the DVD ROM booktype with 1.0.2 UDF.
The following types of audio and video are part of the official plain vanilla DVD spec:
mpeg-1 (VCD) 352 x 240 1150 kbits CBR mpeg-1 layer 2 audio 44 khz
mpeg-2 half D1 352 x 480 (any CBR or VBR within 2kbits min to 9 kbits max) mpeg-1 layer 2 audio 48 khz OR Dolby AC3 OR WAV file
mpeg-2 CCIR 601 704 x 480 (ditto for above CBR/VBR, audio specs)
mpeg-2 full D1 720 x 480 (ditto for above CBR/VBR, audio specs)
Any other video or audio format is not part of the official plain vanilla DVD video spec and will often not be supported for playback on a standalone player. Depending on the player, you might or might not get lucky with non-supported but unofficially widely used formats like SVCD.
A very few standalone DVD players support playback of raw MPEG-2 or MPEG-1 or Divx files but's nowhere in the official DVD video spec. Individual mfrs support that at their whim. -
look at the settings, something is wrong, either the system (pal or ntsc), either the mpeg2 settings.
don;t matter if the audio is mp3 wav or anything else, it re-converts it anyway.
if you converted the files with other soft, make sure it's dvd complliant for the system you use.
just play with it, it's hard to say what the problem is.
Ulead DVD MovieFactory 6 Plus Menu Option Question
By SCDVD in forum Authoring (DVD)Replies: 3Last Post: 26th Jan 2009, 14:42 -
Ulead DVD Moviefactory 6 Plus (trying to get to grips after UDVDWorkshop2)
By dvdfever in forum Authoring (DVD)Replies: 3Last Post: 3rd Jan 2009, 21:01 -
Joining in Ulead DVD MovieFactory - does it lead to worse quality?
By rosbif08 in forum EditingReplies: 2Last Post: 6th Aug 2008, 22:32 -
Ulead DVD Moviefactory 5
By Flying Doctor in forum Authoring (DVD)Replies: 2Last Post: 2nd Aug 2007, 11:43 -
Questions about Ulead DVD MovieFactory 6
By cheeseandcrackers in forum Authoring (DVD)Replies: 5Last Post: 18th Jun 2007, 11:46
