Hi,
I have 2 avi files I have joined with vdub (have also tried Nandub and mp3 freeze). The audio sync i perfect in the 2 source files, but when I join them, the audio starts in sync but gets more and more out of sync.
Is there a program to fix this.
I cant just delete some of time or inset silence, because the sound gets more and more out of sync.
tlund
It sounds like the second file is simply too long (or too short, you don't say which way the drift is). Did you chahge the frame rate of the second part ?
It is a very common problem when joining files. If the end result is conversion to DVD, the usual advise is to encode them as seperate parts and author them as either a single title, or two joined titles. Worst case you get a pause that lasts about as long as a layer break, but sync remains true.Read my blog here.
It is 2 avi (xvid) files i joined to 1 avi (xvid) file. The sync is perfect on the 2 single files before I join them.
And I didn't change anu frame rate. I just opened the first avi, and the pushed File>>Append avi segment, and chosed the other fil. And then Saved AVI.
Years ago I had a little program to change the framerate of the video my avi movie was out of sync. But cant remember the name.
PS: It is not going out of syns suddenly, it just goes more and more out of sync.
AVI to DVD: help with audio sync problems
By tanglemac76 in forum MacReplies: 9Last Post: 23rd Dec 2010, 15:50 -
Joined avi's have no audio
By junee in forum MacReplies: 5Last Post: 5th Feb 2010, 21:40 -
"fixed" AVI has audio sync and video blocking problems
By timur in forum ffmpegX general discussionReplies: 1Last Post: 23rd Sep 2009, 06:00 -
Xvid AVI DVD Playback Audio Sync Problems
By lozza_c in forum Newbie / General discussionsReplies: 5Last Post: 8th Jun 2008, 09:38 -
Why does VirtalDub joined AVI become so huge?
By Pitman in forum Newbie / General discussionsReplies: 3Last Post: 13th May 2007, 13:17
