I installed the VPC5 upgrade the other day and believe that it caused a glitch in VCDImagerEasy which prevented me from processing MPEG files.
I keep the MPEGs in a shared folder, so, even though my virtual C Drive only has 105MB available, the shared folder has 2GB available once the file is being processed.
When I installed the VPC5 upgrade, the Shared folder had zero MB available and VCDImagerEasy refused to continue.
When, in retaliation, I started up VPC Four to process the MPEG, I got the same problem where there hadn't been a problem before the upgrade. Tried trashing the prefs form both versions but no go.
I keep a fresh Windows Hard Drive Image handy in case windows crashes and burns, and after starting up with that, VPC4 and VCDImagerEasy processed the MPEG as before (S L O W L Y)
Anyone know what I can do to get VPC5 to give my shared folder some space? I'm not going to use it if I can't process the MPEGs.
Dave
Results 1 to 1 of 1
Problem with Running Vob2mpg under 'LionCamp'
By Doug Neale in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 27th Sep 2011, 11:26 -
Problem running vob2mpg
By heffneil in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 7th Aug 2010, 10:29 -
System Running Slow when running dvdshrink
By mn072065 in forum ComputerReplies: 7Last Post: 24th Mar 2009, 19:59 -
Problem ripping/copying Running with Scissors
By weflyrc in forum DVD & Blu-ray PlayersReplies: 1Last Post: 16th Jun 2007, 23:12 -
DVD FLICK running problem
By gap0306 in forum Video ConversionReplies: 2Last Post: 14th May 2007, 23:54
