I have a number of avi/divx files that I burn onto a CD-R using Nero 6.6 Ultra. I like watching the files on my DVP 642. But while I can watch these files perfectly on my computer using WMP, after burning onto CD-R to play on the DVP 642, the audio is not in sync? What can I do to fix this? Should Nero be the only application working while the file is burning to CD?
Did you burn the divx file or did you re-encode to DVDVideo?
If you burned the DivX directly, they should work fine (as long as your player is divX compatible). Since timing information is the same. If there is a problem, then it might be you have too high of a bit rate for your player to cope (check its specs and compare with your file)
If you converted to DVDVideo, I cant help there. It is not my specialty!! But I know there are some tools to corect skew problems. Try looking on this forum.
Hope this helps
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
Audio Sync Problems
By mattr in forum MacReplies: 4Last Post: 7th Jul 2008, 09:55 -
Audio Sync Problems
By Blue_3 in forum AudioReplies: 5Last Post: 10th Apr 2008, 18:17 -
Audio sync problems
By sticklebrick in forum Newbie / General discussionsReplies: 1Last Post: 13th Oct 2007, 14:14 -
audio sync prob AFTER burning !
By bluraid in forum Newbie / General discussionsReplies: 5Last Post: 21st Jun 2007, 05:28
