    Jul 2005
    new zealand
    Hi People
    Downloaded a movie two cd's and they are avi files. They play fine on my puter in winamp,videolan or windows classic but cant encode them with TMPGEnc plus , Avic 4cc cant open them either.. vid inspector says I got all the right codec's ..... All I want to do is encode them so I can burn to a dvd that will play on dvd player.. Anyone got any idea's
    Ta Tracker
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    https://www.videohelp.com/tmpgenc.htm#problems
    Try the solution that involves upping the priority of the DirectShow Multimedia File Reader.
    If in doubt, Google it.
    Jul 2005
    new zealand
    I have upped priority to 4
  4. Its not increasing the priority to 4 wil help. You must increase the priority till it reaches the top of the list.
    When I was born I was so shocked that I could'nt speak for 18 months.
