I have a Pioneer 110D and I used DVD Shrink to backup a couple of DVD+r discs I have. I copied them to DVDr's.
The one disc copied fine, but the second DVDr is missing audio on one of the clips. (The DVD disc I copied has various different program clips on it) All the rest of the clips play fine with audio, it's just this one segment. It's fine on the original disc. Any ideas? I'm new to all of this so I'm pretty clueless.
You could check that clip with Gspot or AVIcodec and see what it says about the audio. May be out of spec for a DVD.
If you are just doing a 1:1 copy, DVDDecrypter may be a better choice.
Problem Playing Copied DVD+R DL DVDs from CSS Protected Original
By bpbenda in forum DVD RippingReplies: 10Last Post: 24th Sep 2009, 10:04 -
By bpbenda in forum Newbie / General discussionsReplies: 1Last Post: 23rd Sep 2009, 14:42 -
Copying,Copied DVD-Rw disc to,DVD-R disc
By 306james in forum DVD RippingReplies: 3Last Post: 12th Nov 2007, 12:45 -
Copying, Copied DVD-RW DISC TO DVD-R DISC
By 306james in forum FeedbackReplies: 2Last Post: 12th Nov 2007, 05:44 -
Ive copied a avi disc but it wont play on my dvd player
By popeye39 in forum Newbie / General discussionsReplies: 2Last Post: 9th Sep 2007, 16:26
