I have an mpg2 file and ac3 file with 6 ch. When I tried to author Adobe encore does not accept. Do I need to have plug-in or is there any s/w that supports 6ch AC3 dvd authoring? I am sure TMPGenc does not support it. Thanks in advance.
M.stks
TMPGEnc DVD Author *does* support 6ch AC3 as it allows it to "pass-through" - it just can't encode some other format of audio to it with the AC3 plugin.
If in doubt, Google it. -
Mpeg 2 files are not the best editing formats also.
Quality is my policy. -
I do not want to edit the MPEG2 files. I have MPEG2 compatible to DVD standard, and I have ac3 audio exactly extracted (Matching) MPEG2 file. This just ready to make DVD authoring level, but Adobe encore does not accept ac3 6ch sound. TMPGEnc needs MPEG (with audio and video Mixed), which I do not have. I do not know how to dub using Virtual dub to mix audio and video. Any help appreciated.
TMPGEnc DVD Author w/ plug-in ac3, support;
ac3-2
ac3-5.1
DVDlab Pro, support;
dts
MP4/AAC -> XVid/AC3 6ch
By brugi in forum Newbie / General discussionsReplies: 16Last Post: 20th Aug 2014, 22:43 -
AC3 6ch audio strange behavior in AVISynth
By lovyagin in forum Video ConversionReplies: 10Last Post: 1st Mar 2010, 11:17 -
MKV to MP4 for PS3 with dual-audio (2ch AAC + 6ch AC3)
By sexyclient in forum Media Center PC / MediaCentersReplies: 0Last Post: 7th Dec 2008, 23:01 -
Help please! Want AC3 audio from DVDs but DVD Decrip only makes VOB's
By WBFAir in forum AudioReplies: 6Last Post: 26th Sep 2008, 11:34 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 02:19
