i've got a trial version of TSUNAMI DVD Author Pro which allows you to import DVD-RAM files. But my programs were recorded on a JVC DRM150 and have apparently been recorded at 480x576 which is not a PAL supported format and so it won't let me carry on.
What do I do to get round this as painlessly as possible?
Phil
Not certain if I understand totally, but what are you importing it from??? is it networked (the Program you speak of, or your Set Top Recorder; the JVC..)..
Do you have the capability to to stick a DVD-Ram disc into your PC DVD/CD Rom-Recorder and have it read correctly... Alot of PC DVD Burners/Players aren't DVD-Ram Capable, only a few, Like some LG Models.. Ok.. Now That I got that question for my own curiosity out of the way...Rename the VRO or VOR file from your DVD-Ram source to MPEG, and re-author to Pal Standards.. Works for me, I use a Panasonic DMR E80H to record onto a DVD-RAM Disc, then transfer the source into my PC via my LG Burner, and rename the main Movie File to MPEG...Then it's on to the time consuming process of re-authoring it to the standard which I want it to be..
PARANOID??!?! WHO'S PARANOID ?!?!
Although 480X576 is not a standard DVD frame size, many DVD player which supports SVCD is able to play MPEG2 files on DVD with this frame size. I do it quite often when I want to put more than 2 hours of video on a DVD.Originally Posted by phancey
In order to put 480X576 video on a DVD, you need to fool most DVD authoring tools into believing that the video has a 720x576 frame size. Otherwise they won't let you continue. The tool I used is DVD Patcher which is a freeware. I haven't seen a guide for exactly the situation described here. However, I hope you will find the following guides useful.
https://www.videohelp.com/forum/userguides/187390.php
http://www.doom9.org/mpg/svcd2dvdr.htm
Note that since the audio sampling rate of the video recorded by JVC is already in 48KHz, no conversion is necessary. -
thanks I'll take a look at these links.
Yes I have a drive that reads RAM (LG GSA4040B). I thought I was re-authoring by using TSUANMI MPEG DVD AUTHOR PRO but it moans about the initial format.
Copy of a Copy of a Protected VHS Tape to DVD
By solarblast in forum DVD & Blu-ray RecordersReplies: 12Last Post: 18th Dec 2008, 07:36 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 07:26 -
how do i copy DVD RAM discs to pc hard drive (retaining exact file quality)
By mnbvc in forum Authoring (DVD)Replies: 3Last Post: 19th Apr 2008, 17:32 -
Copy recorded DVD-RAM to DVD-RW?
By Trollheart in forum MediaReplies: 11Last Post: 15th Apr 2008, 14:32 -
Is there way to copy a Dvd realtime with RAM drive like a standalone playr?
By Blumphf in forum DVD RippingReplies: 18Last Post: 25th May 2007, 06:21
