  1. Member ann coates's Avatar
    Jun 2004
    New York
    What does everyone here use? I just got a new writer (Pioneer 110D - love it) and don't know what to pick up. Seems a lot of people use Nero, but it also seems Nero adds a lot of unneccessary add ons that I doubt I'll ever use. Do they only sell the $100.00 Nero Ultra or do they sell a more basic stripped down version? Can anyone offer me recommendations for a reliable, basic, reasonably priced program?
    USA
    Burnatonce, DeepBurner are two freeware programs. A lot of us use DVDDecrypter for burning with DVDShrink. I use Nero also. I don't really use the other features of Nero, outside of DVD data discs and CD data discs.. There are more burning programs in 'Tools' to the left. <<<
    The burning program you use is not really a important part of making a DVD. They mostly all do the same thing, some maybe a little easier or better. I also use TMPGEnc DVD Author for both authoring and burning at times.
  3. Member ann coates's Avatar
    Jun 2004
    New York
    Thanks redwudz, I appreciate it. I'll give those freeware programs a go.
  4. Member slacker's Avatar
    Jan 2004
    SF, CA, USA
    I burn with DVD Decrypter as well. The ONLY issue with DVD Decrypter I can find is that since the software is not supported anymore, it is not updated for new burners and write strategies. With my hp dvd640e and Verbatim mcc0-004-00 discs, it will only burn at 8x while all my other software will burn at 16x. But it does burn FLAWLESSLY at 8x everytime.
    Aug 2005
    North America
    Hi Ann, Glad you like the PIONEER as I was one who recommended this drive! Mine LOVES the Taiyo Yuden DVD-R media, TY02 and TY03. Not a coaster yet in over 100 burns.
    As for burning software it depends on what you want to do. DVDDecrypter is a great program for backing up movies on DVD.
    For basic DVD authoring there are NERO OEM suite software offers out there for just a few dollars.
    Again, burning is a broad field. It depends on what you want to burn.
  6. Member ann coates's Avatar
    Jun 2004
    New York
    Hi Steven,
    Yes, thank you so much for that recommendation! I absolutely love the Pioneer 110. I should have bought one a long time ago, don't know why I held out. Newegg had it for only 46.00. (They finally came back in stock)
    Thanks also for your advice on burning software. I used DVD shrink today and that worked great. Right now I'm looking for a program to use for burning files to DVDr discs as data. Any recommendations?
    Aug 2005
    North America
    Hi Steven,
    I use an inexpensive NERO OEM suite. This is just an example. I'm not recommending this seller:
    http://cgi.ebay.com/New-Authentic-Ahead-Nero-6-OEM-suite-CD-DVD-Burning_W0QQitemZ71829...QQcmdZViewItem
    This software is frequently shipped with optical drives in retail packages and is a good, general purpose burning/authoring program.
    Good Luck-Steve
  8. Member ann coates's Avatar
    Jun 2004
    New York
    Thanks Steve! I'll give that a go.
