im following a guidei n this site on how to add subs to a xvid,at first i couldnt load the file into virtual dub because i didnt have the xvid codec but now i downloaded XviD-1.0.3 and everything was going alrigh then i added the textsub filter and added the .srt file to it,then in video i chose full procesing mode and in audio direct stream and in the compresion mode i chose the xvid codec,but when i click save avi an error ocurred telling me that there was an error and that virtual dub needed to close,i dont know whats wrong and any help will be greatful,thanks in advance
Results 1 to 18 of 18
nope its not the textsub filter,i tried it again without it and it still crashes,i also have downloaded other virtualdub versions but this ones keep telling me when i load my video that "virtualdub has detected an improper vbr audio encoding in the source avi file and will rewrite the audio header with standard cbr values during processing for better compatibility",how can i fix that? because the virtualdub that keeps telling me that can save the avi with the filter ok and all that.
About the VBR mp3, use VirtualDubMod.
You could also try updating XviD:
http://mirror05.x264.nl/celtic_druid/force.php?file=./xvid.cvs.head.exe -
I had a similar problem when I tried to use XviD. VirtualDubMod gave me an Error message when i tried to "Save as Avi". Make sure when you choose XviD and then click on Configure, that the Encoding type is Single Pass. (that's what solve my problem).
Hope that helps.
Bye -
The first thing to try is just ignoring the message. It might save the audio just fine.Originally Posted by Valholy
If the audio gets out of sync, turn on Audio -> Full Processing Mode, select an audio compression codec and encode again.
If the audio is still out of sync then turn on Audio -> Full Processing Mode and save the audio as a WAV file. Then use that WAV file as the audio source.
If even that doesn't work, use another program to extract the audio from the AVI as a WAV file. Then use that WAV file as the audio source. -
ill try all those things,btw i downloaded the xvid codec posted before by celtic druid but it gives me the same error, ill try to make the separata wav file ,one more thing,when i try encoding in full processing mode the file is to big... like 85,324 mb o_o
You're getting uncompressed RGB when you select Full Processing Mode. Select a video compression codec if you want something smaller.Originally Posted by Valholy
wich codec do you recomend me,and is thatok because when i try to put the direct stream option it says that you need to put full procesing mode to be able to put the subtitles in it
If you use the plugin via AVISynth instead you can set it to fast recompress.
The codec that you select depends entirely on what you want at the end. If you are doing hard subs for a standalone AVI/MPEG4 player, then you would have to select a compatible codec (XviD, DivX, libavcodec, skal, HDX4, etc.) if you are just wanting to save an avi to then convert to something else then you should use a lossless codec (FFV1, huffyuv, VBLE, etc.) or better yet don't save anything, just frameserve. -
thanks guys you helped me a lot, specially you celtic
,now i have my subtitles in my video and i burned it to a dvd
problem with compression using virtual dub
By jpez1 in forum Video ConversionReplies: 4Last Post: 3rd Aug 2010, 13:24 -
Virtual Dub problem
By rocka in forum EditingReplies: 3Last Post: 2nd Jan 2009, 03:46 -
Virtual Dub Mod Saving Problem
By cdgfx84 in forum Video ConversionReplies: 2Last Post: 1st Sep 2008, 13:08 -
Simple Virtual Dub Problem...
By tetzy in forum EditingReplies: 2Last Post: 22nd Feb 2008, 19:49 -
Ripping DVD & Virtual Dub Problem...
By Chana1 in forum DVD RippingReplies: 7Last Post: 8th Jun 2007, 07:45
