After lots of trouble I can finally successfully rip a DVD to my HD then encode using DVD2AVI > TMPGenc. My settings are typical XSVCD settings - that is to say 480x480 at CQ (constant quality) 100%. I need to keep bit rate under 2100 so I put max at 1900 to leave room for the audio. I have the highest quality (slowest) setting chosen as well. The net should be a great looking XSVCD, right?
When I playback before burning (through PowerDVD) I notice that any motion has a weird effect (the area around the motion looks sliced while movement is happening). The scene I was looking at was not high motion so I shudder to think what a true motion scene would look like.
What is the highest quality setting here? Since this is a pure rip to encode I am guessing there is no codec at work, correct? The source (DVD) is as good as it gets so what am I doing wrong?
thanks,
mkirk
What does the rip look like before you encode it to XVCD with TMPGEnc? Is there blockiness there also? If so, TMPGEnc will not correct this. You would then need a better rip. If the rip looks good before using TMPGEnc, then look in the guides to the left to find some good settings.
try using the force film option in dvd2avi. i was having the same problem and this worked.
I will try "forced film".
I am surprised I did not run over that in the forums before. What are the other optimal settings in DVD2AVI? There's settings under video for "IDCT Algorith" and Color Space" which I've kept to default setting.
Thanks again... I'm ripping and encoding now so I'll let you know if the quality improves.
-mkirk
How do I convert subtitles to plain text?
By jwbrasil2 in forum SubtitleReplies: 3Last Post: 25th Dec 2012, 15:35 -
Query: Best way to go from a cda. file to plain PCM is ??????
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 6Last Post: 22nd Jun 2010, 20:46 -
make a plain table in CSS?
By lordsmurf in forum ComputerReplies: 9Last Post: 12th Oct 2007, 15:15 -
Plain menu with fancy effect question
By TBoneit in forum Authoring (DVD)Replies: 5Last Post: 11th Jun 2007, 10:41 -
converting subtitle file to plain text?
By shenacat in forum SubtitleReplies: 1Last Post: 2nd Jun 2007, 16:16
