hello all
I have a rather strange problem.
i have an IBM A30 laptop, 800MHZ, 1Gig ram, 128MB radeon video.
i would like to playback movies using QT player.
my graphics are weird as they act as if there is a loose cable to the display and become sketchy and garbled, but only during video playback and every other player except QT does this. this is the only player that plays back video ungarbled.
this isn't a software problem as i do regular installs, updates, complete formats etc. it seems that perhaps QT accesses different sections of the video RAM maybe.
QT will play the video part of DIVX encoded AVI files, but not the MP3 encoded audio.
is there a plugin for QT that will play the MP3 audio so i can watch movies without scrambling my eyeballs?
thanks good people
Sounds like a codec issue. You should be able to get any of your players to work.
Google is your Friend -
it's not a codec issue as i think QT handles codecs differently to other players.
i have, however found the solution to the scrambled video and that's by turning off overlay in performance options in media player.
can anyone tell me what exactly overlay is? -
i turned off overlay in windows media player and all vids worked perfectly. can i also turn it off in vlc? vlc and other players still play a garbled picture
whoohoo
i finally sorted out my garbled video problems? after 6 months. and all it was is turning off the video overlay option.
thanks good people
replies much appreciated -
Even though this thread really seems to have more to do with video playback than with mp3, I do know this:
QT should be able to (natively) play just about any mp3, if in a QT movie or alone. It does have trouble with AVI (incl. DivX), MPG (muxed system/program streams), or MP4, but I believe that has more to do with the demuxing than the decoding.
Note: QTPro won't (natively) export to mp3, but the feature can be enabled with Cleaner, ProCoder, Sorenson Squeeze, etc.
(glad to hear you've worked out your troubles)
Quicktime - Blocky/Pixelated Playback of Mov files
By marcrp in forum Newbie / General discussionsReplies: 4Last Post: 7th Mar 2011, 09:17 -
Apple Quicktime Mpeg2 playback Component
By macuser1960 in forum ffmpegX general discussionReplies: 0Last Post: 2nd Mar 2009, 11:33 -
MIDI Playback from Quicktime
By jonghyunchung in forum AudioReplies: 4Last Post: 28th Jan 2009, 19:52 -
No AVC1 avi playback in quicktime
By roper in forum MacReplies: 6Last Post: 11th Nov 2008, 13:42 -
dv capture and playback doesn't work anymore (except in quicktime)
By richardlode in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 15th Jun 2008, 01:22
