I have a XMS 888 player. I have xvid video files whih I need to check to see if they are compatible on the player. Well apart from burning it to dvdrw and checking it. Is there a tool which tells me the codec and the subsettings used for the codec like for example GMC, Qpel and stuff?
thanks
Are u sure it give information like if the Video is encoded with Qpel and GMC, where do I find this info? I have used it previously but dont know where to look thanks
ASF/WMV - DVD-player compatibility
By Digiface in forum Video ConversionReplies: 3Last Post: 12th Jan 2009, 12:02 -
Apex DVD player AD-1100W - remotes compatibility
By Matthias in forum DVD & Blu-ray PlayersReplies: 5Last Post: 2nd Dec 2008, 13:16 -
dvd player with the best compatibility?
By JCWagener in forum DVD & Blu-ray PlayersReplies: 23Last Post: 16th Nov 2007, 21:17 -
DVD Media & Player Compatibility
By pbisaillon in forum MediaReplies: 14Last Post: 3rd Nov 2007, 17:07 -
Oppo Player HD-Divx Compatibility
By N8theGr8 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 24th Aug 2007, 13:34
