Just got my Pioneer 530. The noise is awful, it's problably from the HDD / fan or both. It's a mid-high frequent constant beep which drives you nuts after a while
Have anyone experienced this before with any Pioneer device?
/Nisse
I received one on a couple of weeks ago for Fathers Day and it runs like a dream. If you have a noisy unit, I suggest you take it to a service centre and have them check it out .... better to get this type of problem sorted out ASAP rather than later. If the fan happens to be the faulty culprit, you may cause more serious damage (over heating) if you continue to use it.
I talked a friend into buying the same unit and installed it earlier tonight for him, also no noise related problems.
Hard Drive upgrade for Pioneer DVR-530/630H
By Hkan in forum DVD & Blu-ray RecordersReplies: 55Last Post: 22nd Aug 2012, 02:07 -
Help with hdd replacement, Pioneer DVR-RT601H.
By Orele in forum DVD & Blu-ray RecordersReplies: 1Last Post: 30th Aug 2009, 13:39 -
Pioneer DVR-530 disc tray doesn't open
By Alex_x in forum DVD & Blu-ray RecordersReplies: 3Last Post: 22nd Sep 2008, 17:39 -
Pioneer DVR-545HX --- HDD Error
By der Heiko in forum DVD & Blu-ray RecordersReplies: 0Last Post: 10th Aug 2008, 10:53 -
Pioneer DVR-541HS HDD upgrade
By AngusMacGyver in forum DVD & Blu-ray RecordersReplies: 4Last Post: 29th Apr 2008, 15:32
