I have recently completed a compilation using encore to create my menu's/submenu's etc. The project is at last sucessfull however one small hitch has got me stumped.
With the DVD laoded on my standalone it starts up at the menu ok, I can navigate to a submenu no problem and skip to a set chapter but, if I want to return to the menu, using the remote, nothing happens, the dvd just keeps on playing.
Am I missing something within my menu creation somewhere??
Hmmm, time to kick ass and chew bubble gum....But am all outa gum.
It's all about setting your end actions and overides.
I also don't quite understand what you mean. Are you trying to back up to a previous menu from a chapter of a clicp you are viewing? Depending on your remote, all I can do with mine is to press the menu button to go back to main menu. It won't let me go to a sepcific sug menu. I also make sure I place " next " and "previous menu" buttons on all my Main and sub menus as that will pretty much insure you will be able to navigate. From the middle of a clip???? I can never ga back to that particular chapter's sub menu unless you remote has the function to take you back to a root menu as well as subs. Did you test it with in Encore using their virtua remote. It has a little button for "end play" action so you do not have to sit throught the whole clip to see it the asigned end action works. Once I test it and it passes 100% it performs 1005 when I burn it.No DVD can withstand the power of DVDShrink along with AnyDVD! -
Ahh the joys of learning....at this rate I reckon I will have snuffed it before I become totally competant in this hobby.
I was probably incorrect in my description, what I mean is that when I want to return to the menu, by using the remote controll, nothing happens. I am just reading a small review on the web now.
http://www.adobeevangelists.com/pdfs/PS2DVD_12step.pdf
Step 11 seems to be were I am goin wrong.
I think the issue is that i did not select the "menu remote" section in the properties panel or is it something similar I have missedHmmm, time to kick ass and chew bubble gum....But am all outa gum.
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
loop point/transitions glitch in adobe encore authored blurays
By tikigod19 in forum Authoring (Blu-ray)Replies: 1Last Post: 31st Oct 2011, 06:40 -
Encore CS4 loop point problem
By sebaz in forum Authoring (Blu-ray)Replies: 0Last Post: 27th Jul 2010, 14:14 -
DVD Lab Pro 2's Render Menu Motion - Intro and Loop Questions?
By xhonzi in forum Authoring (DVD)Replies: 3Last Post: 21st Sep 2009, 17:52 -
DVD - 5 Titles, No Menu -- How to loop back from 5 to 1 at end??
By cykedout in forum Authoring (DVD)Replies: 3Last Post: 27th May 2008, 22:10
