I believe my needs are simple.
All I want to do is make a nice DVD from my home movies, but I'd also like to be able to make compilations up from bits of other DVD's (like taking all the music videos and putting them onto one disc).
Can you suggest anything that will do this well?
Many thanks
Chris
Tmpgenc dvd author or tmpgenc dvd author pro.
To add clips from other dvds select add dvd video, choose the video_ts folder on the dvd(rip it first with dvddecrypter if it is an encrypted dvd) and use the built in editor if you want to cut.
If you want an all-in-one tool, also video converting, try ulead dvd moviefactory or ulead dvd workshop. -
Just tried itNo DVD can withstand the power of DVDShrink along with AnyDVD!
Does a simple AVCHD authoring program exist like DVD programs?
By Killer3737 in forum Authoring (Blu-ray)Replies: 4Last Post: 29th Sep 2011, 11:16 -
Simple DVD Authoring
By DeathStalker77 in forum Authoring (DVD)Replies: 22Last Post: 26th May 2010, 01:40 -
Simple VOB authoring solutions
By kippard in forum Authoring (DVD)Replies: 5Last Post: 22nd Jul 2008, 08:27 -
Again on Simple DVD authoring
By asadfx in forum Newbie / General discussionsReplies: 1Last Post: 22nd Nov 2007, 07:22 -
Authoring a simple DVD
By asadfx in forum Newbie / General discussionsReplies: 2Last Post: 21st Nov 2007, 15:54
