Some authors says thet Hyffyv is the best codec for AVI capturing bit others says Pic M-JPEG is the write choice.
Acording to my experiance using both of them, here is the big difference in
created AVI file.
Using Hyffyuv, 1 hour captured video 720x576 = 40GB AVI file
Using Pic M-JPEG 1 hour same size = 5 Gb AVI file.
That's huge difference in size, but in quality????
Results 1 to 15 of 15
QUALITY HAS A NAME
Read my little test
https://www.videohelp.com/forum/viewtopic.php?t=279500
I prefer using picvideo mjpeg codec. Just set to maximal quality 20. 1 hour captured at 720x576 is 35 GB -
Using PicVideo MJPEC codec, 1 hr of video should be around 12~13GB.Originally Posted by SerbianBoss
but if you using picvideo mjpeg at the best quality 20 1 hour is 30-35 GB, thats sure
huffy is not actually lossless. It just doen't compress much. I prefer pic at 19 because of the size. I can see some difference in qulaity if I zoom in about 8x, but I can't see the difference once it is all put on the tv.
I no longer capture with a computer capture card ... but when I did I used PICVideo MJPEG on the 19 quality setting. This was due to HDD space and the fact that my computer was SLOW at the time ... using the 20 setting caused dropped frames and HuffyUV would also, once in a way, cause dropped frames.
Once I got a faster computer I tried both PICVideo MJPEG at 20 and HuffyUV and I liked PICVideo MJPEG at the 20 setting better than HuffyUV. It seems that HuffyUV does something "strange" to the luminance levels whereas PICVideo MJPEG looks more dead on to the original.
Anyways now I have a stand alone DVD recorder with a built-in HDD but I do have some tapes that need that "special touch" you can only get on a computer using AviSynth so when I get around to them I will probably go with the DataVideo DAC-100 which is a DV capture device ... nearly a "clone" of the infamous Canopus ADVC-100. I just can't seem to get my new and very fast computer to keep sync with my old PCI capture card that I used for years on an older and much slower computer but one that would keep sync none-the-less.
At the moment I'm more interested in capture ... or recording if you will ... from TV programs and there the source is generally "clean" enough that a stand alone DVD recorder is the way to go unless you have obscene amounts of time to kill ... or not that much you are recording.
The program that's invoking HuffYUV tells it what format the image data is in.Originally Posted by payton34
FulciLives, huffyuv is lossless. How is it possible that it was messing up your video data?
No. I had TheFlyDS working on the old computer then got iuVCR to work. Never could get VirtualVCR to work right even on the old computer.Originally Posted by The_Doman
I tried TheFlyDS, iuVCR and VirtualVCR on the new computer with the same capture card I had in the old computer (AverTV Stereo PCI card which is BT based) yet no joy with sync. It will slowly drift so once you are maybe an hour into the capture you start to notice.
Maybe I'll give it a try. A friend of mine needs a VHS of his captured and it definately will need some AviSynth clean-up.Originally Posted by The_Doman
Currently I am having too much fun using the Pioneer DVR-531H-s stand alone DVD recorder ... but using it only for TV stuff.
Look at this pic Do I need a PCI or AGP video card in my PC
By marionr26 in forum DVB / IPTVReplies: 4Last Post: 12th Feb 2010, 01:34 -
Is this a video Codec issue? The videos have jagged/rough edges (PIC) Incl.
By Ricky_S in forum Newbie / General discussionsReplies: 11Last Post: 30th Sep 2009, 20:57 -
Making a video from pic
By abdelilah in forum EditingReplies: 3Last Post: 30th Jan 2009, 13:36 -
Video playback went CRAZY?! (PIC attached...)
By sunsetblvd in forum Software PlayingReplies: 5Last Post: 10th Aug 2007, 21:02 -
Video/pic quality - Bit Rate, Dimensions...?
By tigerb in forum Newbie / General discussionsReplies: 5Last Post: 5th May 2007, 13:02
