What media plays mp4 files? Or what codec do I need?
Results 1 to 17 of 17
you can also install the xvid codecs. they support mp4 playback and also ac3 audio
XviD supports decoding of ASP MPEG-4 Video from mp4. That is it. It doesn't support AVC, ttext, aac, etc. or AC3 which has nothing to do with mp4 anyway.
Quicktime's mp4 support sucks. Doesn't support ASP MPEG-4, doesn't support HP AVC, doesn't support he-aac, doesn't support mp3 in mp4, doesn't support ttext in mp4 (does in 3gp), etc.
I tend to use DivX, myself.
I love my Archos when it comes to air travel...
I tried installing the various codecs, ffdshow, Xvid, haali's splitter but none of them worked.
Running it through Gspot everything is N/A except it says it's a NONAVI file type unknown.
I don't understand. I have Divx and Xvid Codecs installed. What others can I try?
Do I have to have haali's splitter and ffdshow installed at the same time? -
Thank you that VLC player worked, however one more question, is there a way i could just have it play with Windows media Player? What codec could make the mp4 play like all the other mpegs?
I already explained what you need.
and yes you need ffdshow (or other compatbile decoders) and haali's splitter installed at the same time. Otherwise you don't fulfil requirements 1 & 2 as outlined above.
The good thing about ffdshow is that it supports ASP, AVC, aac and mp3 decoding. Its subtitle render may also support ttext and Nero VOB subs. Other issue though is that you can store whatever you want in mp4 as private streams, the only examples that I have really seen so far though are apple lossless audio, nero subs, theora and vorbis.
One last thing. ffdshow needs to be enabled to decode whatever streams and for MPEG-4 oddly enough you need to enable DivX 4 since that is the option that handles mp4v. -
I did install ffdshow and Haali's splitter and all it did was play the video in Windows Media Player, it had trouble downloading the audio codec to play audio. Any suggestions there?
I looked in the audio configuration and all I saw was ac3, is there another place where I can find the faad2 or realaac?
It was already set on the ACC Realaac. But the video still played without audio. Windows Media Player said it had an error downloading a codec. Not sure which?
which 'create DVD from MP4" app for Mac that takes any kind of MP4?
By callagga in forum Authoring (DVD)Replies: 1Last Post: 25th Jan 2012, 20:46 -
trouble with audio after appending a .jpg turned .mp4 to another .mp4
By canadianjameson in forum Newbie / General discussionsReplies: 7Last Post: 26th Jun 2011, 10:55 -
ffmpeg help... convert mp4 to jpeg array, and back to mp4 - problem!
By SaskVideoMaker in forum Video ConversionReplies: 2Last Post: 4th Feb 2011, 05:53 -
loop mp4 or avi locally so will play on mp4 player - ?
By marinebc11 in forum Video ConversionReplies: 3Last Post: 3rd Oct 2010, 21:24 -
Converting to PS3 .mp4 with MP4 Converter on Mac
By The Sumerian in forum MacReplies: 2Last Post: 29th Dec 2008, 22:24
