Hi all,
I have a folder with 24bit 192kHz .wav files which are for a DVD-A.
I used Wavelab to burn them to a DVD-A, but the player (Toshiba SD-2500) does not recognize this disk (or the format I believe)).
It does however have a 24bit 192kHz DAC. Does anyone know of any way to burn a DVD-R so that the music will play in all its glory?
Regards,
Martin
Very few players support DVD-Audio,the only way to play is to make a DVD-Video.
I know the Toshiba 4900 plays DVD-Audio. -
DVD-Audio feature to playback those discs are found in the higher-end DVD players, which costs several hundred dollars. They also have the ability to play SACD discs as well. Coupled with the correct receiver, the sound quality can blow you away.
VTMI have the staff of power, now it's up to me to use it to its full potential to command my life and be successful. -
So would it be right to say that the 24 bit, 192kHz DAC labelled on the front of this DVD player is pretty much useless?
Seems a bit like false advertising if so.
Is there any other way I can burn these .wav files and enjoy their quality, and if so what tools/programs would I need? Have searched with no luck so far!
Cheers -
Hiho,
to replay a DVD-Audio you need a DVD-Audio compatible DVD-Player
sorry dude Toshiba SD-2500 isnīt the right toy for this format!Toshiba SD-2500 DVD Player
Advanced 24-bit/192kHz Audio DAC
DTS and Dolby Digital Compatible Output
DVD-Video, DVD-R*, VCD, CD, CD-R/RW*, MP3* Compatible
Enhanced Picture Mode (EPM)
Enhanced Audio Mode (EAM)
3-step zoom in and 1 step zoom out
CD Text Compatibility
10-bit/27MHz Advanced Video DAC
Component Video Output
Optical and Coaxial Digital Output
possible solution:
Try to author your WAVs (only possible with two channel not multi channel) into a DVD-Video with DVDlab (keep in mind the overall bitstream if youīre chosing your dummy video track - suggestion: use the audio mode inside DVDlab - this will work) and hope your player will accept this curiosity inside a DVD-Video (itīs part of the DVD-Video standard but until now I havenīt found a player which replays it without downsampling it to 48kHz)
give feedback
CYA Daphy -
Thanks for the replys folks.
I think I might have to get a new DVD-A compatible DVD player in the near future, as I don't think it's worth downsampling to something near CD quality because I already have the CD.
Thankyou though for confirming my equipment is not up to the task at hand.
Many thanks,
Martin
Help. What program to use to make avi files play on dvd player?
By xxxThiefxxx in forum Newbie / General discussionsReplies: 13Last Post: 30th Mar 2010, 18:09 -
Want to make hi-def DVD to play in blu-ray player
By amfriedman in forum Authoring (Blu-ray)Replies: 3Last Post: 24th Mar 2009, 22:12 -
How low can I make xvid bitrate and still play on new DVD player?
By jimdagys in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 22:07 -
How to make DVD from avi file to play on dvd player on tv
By marjolein01 in forum MacReplies: 11Last Post: 3rd Jan 2008, 12:37 -
Trying to make a DVD play on windows MEdia Player
By WuTangDvD in forum Software PlayingReplies: 6Last Post: 23rd Oct 2007, 09:24
