Hi guys im new to this, and i really want to know how to sub a XVID and change that XVID into DVD so i can burn it. Right now i have the XVID and the sub file .SSA can someone show me where to start from now. PLS show me in detail... THX
Results 1 to 9 of 9
try this - https://www.videohelp.com/guides.php?link=697. If it's not exactly what you need, try using the how-to menu to the left, choose convert, and voila! Just pick your format.
occasionally larger than 255 characters -
i cant open the movie file with virtualdub because that program doesnt play xvid.
ok.. so i tried loading tmy XVID movie up with virtualdub, and i have an error message saying, "couldnt locate compressor for format "XVID: VirtualDub requires a Video for Windows (VFW) compatible codec for the compressor video. " What does that mean and what am i suppose to do? pls help
It means you're missing the codec. You need a Codec information tool such as GSPot (for AVIs) or AVICodec (for AVIs and MPGs) that will tell you exactly what codecs you need and whether or not you have them. You can then search for then through the "codec" link on the column to the left of this page, or google for it.
Oh! and if it's an AVIi, use GSpot also to see whether you can render the file or not. I've found that sometimes the codec is installed, but it isn't "useable" because it's integrated with another program. -
rotflmao...............Originally Posted by lonelyboi06How Big A Boy Are Ya?
What's best to burn to DVD: XVID, DIVX, AVI?
By peterj in forum Authoring (DVD)Replies: 3Last Post: 17th Jan 2008, 08:35 -
Best Way to Burn HD Xvid files to DVD?
By expat in forum Newbie / General discussionsReplies: 5Last Post: 28th Sep 2007, 11:51 -
Can you burn Xvid files to DVD so they will play on stand alone DVD Player?
By JoeBolden in forum Newbie / General discussionsReplies: 4Last Post: 3rd Aug 2007, 17:48 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 21:46 -
IngBurn can't burn xvid
By crowheart in forum Newbie / General discussionsReplies: 2Last Post: 16th May 2007, 16:27
