is there anyway to navigate vobs in mpg2cut2 frame by frame? or are there any other video cutters like this that allow you to go frame by frame?
Cuttermaran, Womble mpegvcr, to name two.
Cheers, Jim
My DVDLab Guides -
Videoredo does also, and is IMO easier to use than the tools listed above. It lets you navigate by frames or by whole GOPs, and it has a setting in the options which lets you switch between GOP-level cutting and frame-level cutting. And it has an option to display an indicator with each frame showing if it's an I-frame or not.
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 11:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 13:24 -
mpg2cut2 for MPG file
By bz186 in forum EditingReplies: 13Last Post: 13th Sep 2009, 05:50 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 15:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43
