hi, i used dvdremake pro v3 to merge 2 dvds, (2gb each) , but i had a problem,
i got the 1st dvd menu in the video manager , and the default dvdremake pro menu (wich allows me to choose wich disc) is located in the 3rd vts, when i burned the project, i got a playable dvd in my home cinema player, but it plays the 1st dvd menu, then it stops, i have no red icons in the project ( so there are no errors) ; the only problem is that i want to get a project wich contain the default dvdremake pro menu in the video manager section,
plz heeeeeeeeeeelp
this is the screenshot of my project
i think the right project will contain, the default dvdremake pro menu (choose disk 1 or 2) , and the two dvds in one vts each , right ??
plz help me,i tried about 50 times and it doesn't work, it's been a week now
thx in advance !!!!!
You might be better off going to the support forum, but offhand I think you probably need to modify the firstplay instructions in the VMG.
However, I can't tell since you didn' expand that in your screen shot.
Camcorder Video to Several DVDs with menus
By vanillafrozen in forum Newbie / General discussionsReplies: 1Last Post: 9th Oct 2011, 04:12 -
How to Edit DVD Menus incl overlay pictures over video Sony Vegas DvdRemake
By c627627 in forum Authoring (DVD)Replies: 2Last Post: 20th Feb 2011, 20:19 -
Problems Merging DVDs
By npjs31 in forum Newbie / General discussionsReplies: 2Last Post: 29th Feb 2008, 02:44 -
How do you make menus for dvds....
By mmmipa in forum Newbie / General discussionsReplies: 1Last Post: 2nd Nov 2007, 12:33 -
Menus on DL-DVDs created with DVDShrink...
By takearushfan in forum Authoring (DVD)Replies: 2Last Post: 12th Sep 2007, 01:48
