forgive my termonology first off but here it goes.
well I'm trying to take my avi version of final fantasy advent children and make it a correct resolution for a dvd. The resolution on the avi is wacky though it's 608x336. I'd like it so that the video doesn't even go a pixel off my tv screen. I've always had problems with this. I'm not a newb when it comes to this (I promise) It's just i've always had a hard time resizing it right. If there's an easy way let me know. Of course I'd like to keep it close to the same aspect ratio. If there's anything else you need to know let me know I can get you specs with virtual dub. I can use other tools that you suggest tools I'm experienced in many. Usually what I do is open up the avi is demultiplex the video from the audio using tmpgenc by encoding it at a very high bitrate run it through dvd-lab or another tool that I use made especially for vob multiplexing. Then I compile the dvd then burn it. I still to this day don't know how to encode it so it doesn't trail even the slightest bit off my tv though unless if the source is a normal resolution
thx in advance,
Kgonepostl
It's the M-O-N-O and I can't even spell the rest, it takes too long and I need another cigarette, I can't hear my right ear is mad wack, so stfu and listen or get an ass kickin
alright, what settings do you suggest I change. I don't know how to use this program. Please refer to my previouse post before you post. Because it takes about 15 hours to encode.
It's the M-O-N-O and I can't even spell the rest, it takes too long and I need another cigarette, I can't hear my right ear is mad wack, so stfu and listen or get an ass kickin -
What is your final output? DVD or DivX? If DVD then,
AVISource("F:\source.avi")
LanczosResize(672,352,25,8,557,320)
AddBorders(24,64,24,64)
Thats your 16x9 to 16x9Quality is my policy. -
Try this: Open your 608x336 source in TMPGEnc, before encoding press the Settings button and go to the Advanced tab. Set Video Arrange Method to Center Keep Aspect Ratio. That will give you an active picture that's about 608x306 in a 720x480 frame.
TMPGEnc's resizing isn't the best but it's easy.
Resolution & Aspect Ratio
By markf78 in forum Video ConversionReplies: 4Last Post: 11th Apr 2011, 14:17 -
Resizing: Resolution and Aspect Ratio
By roflwaffle in forum Video ConversionReplies: 7Last Post: 9th Apr 2011, 08:25 -
Resolution and Aspect ratio
By Mrsash in forum Video ConversionReplies: 4Last Post: 19th Nov 2009, 16:37 -
Resolution vs Aspect Ratio
By triptych in forum Newbie / General discussionsReplies: 17Last Post: 7th Aug 2009, 07:23 -
Please explain Aspect Ratio and Resolution
By slmnow in forum Newbie / General discussionsReplies: 8Last Post: 21st Aug 2007, 19:14
