in the video transcoding options for sample format you can choose progressive, interlaced (top field first) or interlaced (bottom field first). ive not got a clue what any of those mean so can someone tell me which option will give me the best results? thanks
If your source is progressive, you choose progressive
If your source is interlaced with top field (Field A) first, you choose interlaced (top field first)
If your source is interlaced with bottom field(Field B) first, you choose interlaced (bottom field first)
What that means you look in the Glossary (here on the left top of the page there is field "GLOSSARY")
More info about interlacing: www.100fps.com -
okay thanks alot... sorry to be a pain but ive got one last question, how do i find out what the sample format of the source file is? i dont know much about this sort of thing if you cant tell.
Generally if your source is DivX/XviD avi it is progressive. If the source is DV avi from camcorder it is bottom field first. If it is avi from capture it is top field first (or progressive).
You can look at the interlaced lines (combing) loading the source in VirtualDub and seek to a place where there is motion.
Now the field order is a bit more difficult. TMPG for example can automatically determine the field order in avi files (IIRC).
Now if your source is DVD it can be interlaced or telecined. Generally holywood movies are telecined.
This you can look loading the file in ReStream. If there is pattern with TFF folowed by BFF - that is telecining. How can Nero deal with this I don't know.
Video Transcoding Examined
By sum_guy in forum Video ConversionReplies: 0Last Post: 9th Feb 2011, 18:06 -
Freezing during transcoding in Nero Vision 4
By TheGMan in forum Video ConversionReplies: 2Last Post: 21st May 2008, 11:09 -
Nero 8 transcoding question...
By RaGuSNY in forum Video ConversionReplies: 3Last Post: 4th Nov 2007, 15:23 -
ffmpeg options for PS3 transcoding
By techid in forum LinuxReplies: 6Last Post: 23rd Jun 2007, 04:40 -
I keep getting an Error while transcoding with Nero Vision 3
By kiaconcepts in forum Video ConversionReplies: 4Last Post: 5th Jun 2007, 08:35
