I've been transferring my old VCR tapes to DVD. All have been burning perfectly Now all of a sudden Nero gives me an 'unble to insert AVI' message when I try to load an AVI file.
I even gives the same error message on files I have already successfully burned.
I've updated my nero to the latest version
Any help please
It could be one of a zillion things.... you're not giving us much to go on here.
1. Between the time you successfully imported one of the avi's until now, have you installed any other programs, codecs, or made any major changes to your comp? Upgrades even?
2. Can you watch these avi's on your comp? Do they play properly?
And Pleeeeeeeeease fill out your computer details. I don't even know what OS you're on. -
Nero can be very picky at times, especially if you upgrade and then throws up strange errors for no reason
Have you installed ANY software before or after you upgraded Nero, sometimes other software can mess things up
Another thing you can try is to uninstall Nero completely, restart your computer, then reinstall Nero. Its a pain I know, but this can cure Nero's problems sometimes -
Just got another error message saying Nero is not compatible with this version of Windows. I have Legit latest copy of Windows Home XP with SP2Originally Posted by steptoe
You've got some old version of Nero, maybe 5.something?
Move to the latest 6, it's worth it.
-Evan- -
Sorry, I should have said. I have latest version of NeroOriginally Posted by QuaiBoy
New error message now says file does not contain any video information. This is a file I have already burned successfully twice before.
Noobish Nero DVD Burning problem (no space available for recording process)
By windowlicker in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2014, 12:24 -
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 12:59 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Sound Problem Burning DVD with Nero 7 and TMPGEnc
By brandonc in forum Authoring (DVD)Replies: 4Last Post: 28th Nov 2007, 20:40 -
nero burning problem
By peterjitonks in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2007, 14:40
