Hi all.
As I am capturing, not so slowly but surely the audio gets out of sync with the video.. my specs are way past what the box says.. Xp2600 2.13 ghz and 1 gbg of ram..
It really begins to be apparent about 2 mins into the capture and just gets more and more out of sync.. anyone have any ideas?
Results 1 to 10 of 10
I bet you are capturing analog to digital right? Would not happen with DV to DV transfer. Are you loossing any frames? Pinnacle it pretty good at DV caps but not so good with analog that your pc has to convert to digital avi or MPG2 on the fly.
Since there could be so many reason for that problem to occur you will need to tell us a lot more. Source of the capture, the card you are using if it is analog would be good for starters.
Analog to digital caps are some of the most strenuous stress you can put a pc through. It's worse if any background programs are running in the background.
So please explain every little detail as to what you are doing as someone here will catch something that may escape someone else as important. Happens all the time. The more detail you give the less time going back forth with post after post till that important bit of info gets mentioned.
Pinnacle if not the greatest at producing and burning DVDs ( authoring ) but it does as pretty good job at caping, editing and rendering. At least it has never failed me on my machine which is simmilar to your specs.No DVD can withstand the power of DVDShrink along with AnyDVD! -
Originally Posted by jtoolman2000
I am using the pinnacle studio pci capture card also if that helps anyone.
I am not sure what else to say. :/ -
Try caping to SOme sort of AVI format and see if it helps. Caping dierectly MPG is never recommended and you really cannot edit PMG as it only allows editing to the I frams which I think is every .5 second. AVI allow frame accurate edits. If you do MPG and edit and them re render to MPG to say author a DVD you will probably loose even more quality and intruduce even more problems.
If you search the forum, you will find numerous users have had sync issues using Pinnacle products.
Rob -
Originally Posted by harley2ride
I use Adobe Premiere, or Vegas Video. Others use Virtual VCR, HuffyUV, or a host of others that work great. Go to the tools forum and resort the capture tools by rating, and you will see the most popular ones.
Rob -
marty which capture card do you use?,if a pinnacle one, which model?, or is it of another brand?
I believe the PCI card ids based on their classic DC10 capture card (MJPEG)
Go up to pinnacle site... they will give you many recommendations on capturing wtih the card. Personally I would shut down all processes and programs that are autoloaded and try again.
I ended up buying another analog capture card due to the ongoing sync issues I was having with my DC10 card.
PINNACLE STUDIO 11 - dvd no audio plays
By ancient in forum Authoring (DVD)Replies: 2Last Post: 10th Jan 2012, 08:07 -
Audio Effect help needed (Pinnacle Studio 11)
By JohnP in forum EditingReplies: 0Last Post: 5th Apr 2011, 04:44 -
Pinnacle Studio UltimateHDv14-audio out of sync!
By rivrbyte in forum Capturing and VCRReplies: 0Last Post: 20th Mar 2011, 21:42 -
No audio with pinnacle studio 12.1 on vista 32 premium?
By yoda313 in forum EditingReplies: 0Last Post: 26th Oct 2008, 15:05 -
5.1 channel audio in Pinnacle Studio 10
By GerritL in forum AudioReplies: 1Last Post: 30th Aug 2007, 09:49
