I am using Epson R200 to print DVD label
I am looking for good dvd-r 0r +r printable
some one help me see what is the ID code for
Prodisc 8X DVD-R White Inkjet Hub Printable ( from supermedia.com) 28$ per 100
I use about 700 Sonic 8x printable from shop4tech with middle ring ( now it no longer available with middle ring that why I can not use that, because tha maximum adjust middle ring of epson r200 only 20 ) with middle ring you set 23 center hole for epson r200.
some one use the better printalble dvd-r please let me know\
I got only 1 burner Nec-3520A
epson R200 with Jwsale CIS.
Thank you for your help
I like the Maxell "Print to the Hub" -Rs. They are a little oversized, but about 1-2mm, but they burn great on my LG 4163. Around my area, I can only seem to find the MIJ ones at Wal-Mart. They're kind of pricey, about $14 for 25, but depending on the circumstances, they are worth it.
Plays on 12 DVD Players
Plays not on 1 DVD Players
Burn Reliability is Mixed
DVD Reliability is Mixed
PC Reliability is Mixed
Console Reliability is Mixed
This mean Prodisc not good at all
Thank you all -
My experience with the printable 8x Prodisc has been excellent. I have burned more than 200 without a coaster.
A year back or so, I order 4 seperate batched of the Pordisc white hub printables form 3 different sources. All 4 got returned because after burning they lots of read errors. I now longer use the Prodiscs, I now spend a few more $$ and use Verbatim white hub prints only (all are MCC)
What We Do In Life, Echoes In Eternity.... -
prodisc +r discs are great, i only got one fake batch, burns great on one burner will burn on others but wont read anywhere, fake disc's are like that so no reason to blame but urself
prodisc is very good grade b media
You probably don't know that Prodisc is one of the major manufacturer for Verbatim DVD and CD media, that's why you always see MCC code in Prodisc media, Fujifilm is Prodisc's OEM customer too !A year back or so, I order 4 seperate batched of the Pordisc white hub printables form 3 different sources. All 4 got returned because after burning they lots of read errors. I now longer use the Prodiscs, I now spend a few more $$ and use Verbatim white hub prints only (all are MCC)
Whats the "material/texture" of the White Injet & White Therm
By ty1er in forum MediaReplies: 4Last Post: 25th Jun 2009, 09:24 -
looking for silver hub printable DVD media
By PharmBoy in forum MediaReplies: 6Last Post: 30th May 2008, 06:31 -
Glossy hub printable DVD+R
By PharmBoy in forum MediaReplies: 9Last Post: 27th May 2008, 09:06 -
TY R47WPP600SK -- hub printable or not?
By spiffy in forum MediaReplies: 6Last Post: 12th Mar 2008, 22:03 -
Taiyo Yuden 16X Water Shield White Inkjet Hub Printable DVD-R Media
By mn072065 in forum MediaReplies: 66Last Post: 28th Sep 2007, 11:29
