  1. Im having a little problem where when im converting form Divx - DVD - I get a
    playback problem. The film has a slight jerking in the film. its not that bad but
    it is noticeable. Im just wondering is this due to a setting i use while encoding
    with TMPGEnc ... ? or is it due to how the film has been ripped in the 1st place ... ?
    or even something else totally altogether ... ?
    I've encoded 100's of films but only just came across this problem as of latley.
    ALL HELP AND POINTERS WILL GREATLY APPRECIATED ...
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    I would expect it is a byproduct of how it was originally ripped. Also, you may be converting from PAL to NTSC or vice versa.
    Google is your Friend
  3. How can i find out if the file im going to convert from is either ...
    PAL or NTSC
    is there a program to find out by anychance ... ?
    Jul 2003
    michigan
    pal-25fps ntsc-29.97fps
    member since 1843
  5. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Also if you are going from NTSC-Film to NTSC you will get this with converters which just add the extra frames and not using pulldown.
  6. Cheers for all the help and pointers. i've found using TMPGEnc 3.0 XPress
    has fixed all problems encountered and im getting excellent results ...
    Many thanks for the help given tho' ...
