    Sep 2005
    Australia
    Hey, I brought a tv-out to composite cord the other day so i could watch what was on my computer on my TV, and what happens is it shows up on the TV when the comps loading and shows the loading screen, but as soon as the desktop comes up it goes blank again.
    Any help would be apreciated
    Aug 2004
    Kansas
    You probably can't expect much help, without supplying reasonable information, such as what hardware, what software, what TV, etc.
    One possibility is that the card defaults to a higher resolution than the TV can handle. Assuming you are running a version of Windows, try right-clicking on your desktop and choose 'Properties'. On the settings tab, reduce your resolution to minimum as a test. If your card came with software you installed, there may be a separate resolution setting so you can set the TV signal to a different resolution than your desktop.
    Sep 2005
    Australia
    Thanks, I just tried that then and still couldnt get it to work.
    Im on XP and have an nvidia cap card.
