Hello there, I've been trying to encode a 700MB avi file and convert it to VCD and fit it into one cd. But the thing is, everytime i encode using TMPGEnc, it goes over the limit, meaning once the movie is finished it keeps encoding. Let me show u and example:
This movie i was able to fit it into one cd and notice the arrow, the number is way smaller than the other movie.
Whilst the other which takes years to finish encoding and has a bigger number than the other one.
If u guys no what that is and why it keeps encoding even though the movie is finished. Here are the settings i used to encode on both of the movies:
Thank you very much!!
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator Cobra
Closed Thread
Results 1 to 10 of 10
First of all, did you mean to post a screen grab? Because it is not here. You are obviously converting some Dvix you downloaded to vcd right? Say this is a 120 min movie, when converted to say MPG2 at a good medium bitrate, it will end up being at least 4 gigs long. You would have to make TWO vcds ( 700 mb each ) in order to make it fit. I did an early experiment with a 90 min Pixar DVD i own, just for laughs. I made a divx with Dr. DIvx using their auto setting to make it fit to one CD. Came out to 695 mb. I then loaded it into TMPGEnc using the VDC template and it needed 1200 mb. Perfectly normal. Now you could of course reduce the bit rate till it fits in one cd iand it should provide with a vcd that will look dismall. As if the Divx actually looked good to begin with. Unless what you are trying to convert is something that is positively not available in a comercial DVD release, it really is not worth the effort.
No DVD can withstand the power of DVDShrink along with AnyDVD!
Hey jtoolman2000,
yes i tried posting 3 pics, but it dsnt work. If u saw the screens that i posted then i think that ud understand what i meant. cud u tell me how to post the pics from my pc? it said that i have to type
thnx. if i cnt then i'll try to explain it to u. thnx for replying!
instead of putting d:/pic2.jpg, just put pic2.jpg inbetween the IMG tags
There's a sticky at the top of this forum that may help:
How do I upload screenshots ?If in doubt, Google it.
hey thnx jimmalenko!!! now im able to see it.
Ok i hope u guys get what i mean now.
Heres the MPEG settings that i used under the video tab:
Stream type: MPEG-1 Video
Aspect Ratio: 4:3 525 line(NTSC)
Frame Rate: 29.97 fps
Rate Control Mode: Constant Bitrate (CBR)
Bitrate: 1150
VBV Buffer Size: 0 (Automatic)
Motion Search prescision: Normal
I'd suggest you re-read the forum rules, particularly the section on warez
oops, sorry bout dat, i didnt mean to post dat part. Just wanted to ask questions bout dis problem wid TMPGEnc sorry bout dat.
No warez. Please re-read the Forum AUP, which can be found here:
https://www.videohelp.com/forum/viewtopic.php?t=124514
Encoding problems
By El Barto619 in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2009, 23:32 -
Problems encoding!
By villa99 in forum ffmpegX general discussionReplies: 4Last Post: 25th Mar 2009, 13:50 -
Problems with TMPGENC 4.0 XPRESS + TMPGENC DVDAUTHOR 3.0 :( help
By neurosys in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2008, 19:37 -
TMPGEnc Plus Encoding
By crys94 in forum Video ConversionReplies: 9Last Post: 29th May 2008, 23:23 -
VBR encoding problems with TMPGEnc 4XP
By maccool111 in forum Video ConversionReplies: 2Last Post: 8th Jun 2007, 05:42
